Are We Affected by 2025 Tariffs? Here’s What You Need to Know (Especially for US Buyers)
If you're a US customer shopping for LoRaWAN® devices and other telecom equipment, gateways, or Meshtastic nodes, you’ve probably wondered: Will I be hit with 70% tariffs when ordering directly from RAKwireless?
You’re definitely not the only one thinking about this. This has been one of the most asked questions we’ve received in 2025, especially with the ongoing changes around the total tariff on China imposed by US President Trump. The good news is that most of our products are not affected by the steep tariff rates.
This blog will break it down, specifically for our US buyers.
You Can Save on Import Fees Even When Shopping from the US
Over 70% of RAKwireless products are officially classified as communication devices under HS Code 8517.62.0090. This means:
- They are not subject to 70%+ tariffs.
- They usually carry a standard 27.5% tariff
If you’re planning to stock up on modules, read on.
Why Our Products Are Classified This Way
Our products aren’t simply modules or components; they’re fully functioning communication devices. They send, receive, and process data over wireless networks like LoRaWAN, Bluetooth, or Wi-Fi.
Here are some examples that qualify under 8517.62.0090:
- WisGate Series – Indoor/outdoor LoRaWAN gateways
- WisNode Devices – End devices with built-in LoRaWAN capability
- 5G All-in-One Gateway
- WisMesh Devices – Like Meshtastic repeaters
- Field Testers
- RAK2270 Sticker Tracker
- WisBlock Kits – When assembled with a Core, Base, and Sensor, and flashed with working firmware
What About Accessories Like Antennas, Cables, or Solar Panels?
Here’s where it gets tricky for US buyers:
If you buy these items on their own, they may fall under different HS codes. And those can be very expensive.
That’s a big difference.
But don’t worry. If you buy these accessories together with a complete gateway or device, we can classify the entire bundle as a communication apparatus under 8517.62.0090.
Pro tip for US buyers:
Always try to bundle accessories with a full device. We’ll assemble and flash it as needed to keep your tariff lower.
What We’re Doing to Help for US Shipments
We’re taking real steps behind the scenes to make your experience seamless and help you find your best way around US tariff on LoRaWAN devices:
- Pre-classifying eligible products: under the correct HTS code.
- Pre-assembling WisBlock kits: into functional LoRaWAN devices.
- Including proper labeling: and invoice documentation.
- Supporting special requests: for US importers who need customs clarification.
Download: HTS Code & Tariff Guide for US Buyers
Want the full breakdown of product codes, classifications, and bundling tips to take advantage of tariff exemption?
We made it short, useful, and easy to share with your customs or finance team.
TL;DR: What US Buyers Should Know
Official References for US Buyers
We don’t just make this up. The US government has clear guidelines on tariff exclusions for communication apparatus.
For further reference, you may consult the following resources for tariff updates.
These sources confirm that LoRaWAN gateways and wireless communication tools qualify under 8517.62.0090 when properly assembled and documented.
Have questions? Our team is happy to help you build the most tariff-smart order possible. Email us anytime at [email protected] or use our contact form.
