New WisMesh Tag, IoT Deployments, WisGateOS 2 Extensions, Tutorials and Guides
Welcome to the RAKwireless Bulletin – October 2025 Edition.
In this edition, we’re unveiling the new WisMesh Tag, a compact, rugged, and ready-to-use Meshtastic tracker designed for adventurers, conservationists, and IoT makers who demand reliability in the field.
Alongside this launch, we continue our 11 Years, 11 Deployments series with six more real-world use cases: from farms in Namibia to airports in Asia.
We also highlight WisGateOS 2 Extensions that turn common deployment challenges into simple, configurable features, share insights from CEO Ken Yu on open-source IoT, and provide hands-on guides to help you move from prototype to production.
Let’s dive into the updates!
New WisMesh Tag: Compact, Rugged, and Ready
The new WisMesh Tag is a pre-flashed Meshtastic tracker built for the outdoors and real-world reliability. Designed for adventurers, professionals, and makers, it delivers endurance, stability, and ease of use right out of the box.
- 1000 mAh Battery: Up to 2–3 days of runtime in the field.
- Stable Bluetooth: Reliable pairing. No random disconnects.
- Dedicated Reset Button: Simple updates and troubleshooting.
- IP66 Casing: Weather-resistant and dustproof durability.
- Globally Ready: Now you can buy and use a Meshtastic tracker across Europe with confidence.
Use Case Highlights: 11 Years, 11 Real Deployments
Last month, we shared five real-world use cases showcasing how RAKwireless technology powers operations across agriculture, energy, and infrastructure. This month, we’re continuing the series with six more deployments.
Use Case #6: From Holiday Tables to High-Tech Barns
Commercial farms are using RAKwireless gateways for LoRaWAN to track power, temperature, humidity, feed, and water conditions, ensuring consistent production and healthier flocks, all year round.
Learn more
Use Case #7: Desert Lions of Namibia - Technology at the Edge of the Wild
RAK solar-powered gateways and mesh networking bring real-time location and health tracking to endangered desert lions, deep in cellular dead zones. This enables silent, uninterrupted data for conservation.
Learn more
Use Case #8: Enhancing Farm Security and Management in Namibia
Sprawling rural farms use WisGate Edge Prime RAK7240V2 to monitor for intrusions, protect livestock, and manage water and pump systems. This reduces patrol time while increasing security and operational control.
Learn more
Use Case #9: Water Is Life on the Farm, And LoRaWAN Keeps It Flowing
In remote paddocks across Australia and New Zealand, solar-powered gateways for LoRaWAN® help monitor tanks and troughs in real-time. The deployment setup alerts farmers instantly to leaks or dry spells. The result? 70% less travel time and saved lives during extreme heat.
Learn more
Use Case #10: Seamless Smart Self-Check-In for Urban Co-Living in Seoul
A 15-story co-living building uses RAK gateways and LoRa-enabled locks to automate guest check-in for 177 rooms. Residents scan a QR code, complete verification, and unlock their door. No front desk required.
Learn more
Use Case #11: Smarter Indoor Environments with LoRaWAN at Hong Kong International Airport
Environmental sensors powered by RAK gateways for LoRaWAN deliver real-time data to facility teams from terminals to SkyPier. The system improves passenger experience, supports carbon-neutral goals, and builds smarter buildings from the inside out.
Learn more
WisGateOS 2 Extensions: Global Compliance, Smarter Gateways
Deployment issues shouldn't require shell access and custom scripts.
WisGateOS 2 Extensions turn common field problems into modular, configurable features, letting you adapt, recover, and scale faster with just a few clicks.
Extension #1: Operation & MaintenanceAuto-reboot LTE when networks drop. Schedule gateway restarts. Reduce on-site visits. Learn more |
Extension #2: Country SettingsLBT compliance for Japan, Korea, and more. No firmware forks needed. Learn more |
Extension #3: Open/Close PortManage firewall-level rules via UI. No iptables, no scripts. Learn more |
Extension #4: Solar BatteryReal-time insights into battery health, charge cycles, and power flows. Learn more |
Extension #5: WireGuard & OpenVPN ClientSecure gateway-to-network tunnels for enterprise deployments. Learn more |
Extension #6: Failover RebootTrigger restarts if all backhauls fail. Learn more |
Extension #7: WiFi RebootStructured recovery logic for flaky WiFi. Learn more |
Extension #8: Field Test Data ProcessorProcess test data right at the gateway. Learn more |
Extension #9: Breathing LightVisual status cues with customizable LED alerts. Learn more |
Extension #10: Custom LogoAdd your branding to the WisGateOS 2 UI. Learn more |
Leadership & Community Voices
Ken Yu on Meshtastic
RAKwireless CEO, Ken Yu, talks to the Meshtastic team about open-source IoT, the 120km island-to-island network in the Philippines, Meshtastic’s power outage rescue in Portugal, and what’s next for WisBlock and AI at the edge.
Tutorials & Hands-On Guides
WisGateOS 2: Auto Data Recovery
Learn how to cache LoRaWAN packets when your gateway goes offline. Prevent data loss during outages or connectivity drops.
WisBlock Enclosures: The Missing Link Between Prototype and Deployment
Discover the universal IP67-rated enclosures for WisBlock and other hardware. Perfect for pole mounting, DIN rails, or rugged outdoor installs.
Stay tuned for more hardware launches, software updates, and solution releases in the months ahead.
