What Verizon Certification Means for Gateway Deployments for LoRaWAN®
For many enterprise IoT projects in the United States, a gateway that “works on LTE” is not always enough.
The device may support LTE backhaul, connect the sensors, forward data, and run the right gateway software. But for real deployments, especially those tied to enterprise networks, facility operations, or system integrator projects, technical compatibility is only one part of the approval process.
Procurement teams may ask whether the gateway is carrier-certified. IT teams may need documentation before allowing the device onto an approved hardware list. Facility teams may want assurance that cellular backhaul will work reliably on the network they already use.
That is where carrier certification matters.
For teams deploying LoRaWAN over Verizon LTE, Verizon certification provides an important layer of confidence for procurement, IT approval, and enterprise rollout.
WisGate Edge Lite 2 Verizon RAK7268CV2-V offers a Verizon-certified indoor gateway option with LTE Cat 4, external LTE antenna support, PoE, and WisDM for enterprise rollout and remote management.
Why Carrier Certification Matters in US Enterprise IoT
Carrier certification matters because enterprise IoT deployments often need to pass more than a technical test.
A gateway may support LTE, but that does not automatically mean it fits a company’s procurement rules, IT security review, or approved device process. In many US organizations, especially those already using Verizon for enterprise connectivity, carrier-certified hardware is easier to approve, specify, and standardize.
That is the practical difference between LTE support and carrier certification. LTE support means the hardware and modem are capable of operating on compatible LTE networks. Carrier certification means the device has completed the carrier's certification program and has been validated against that carrier's requirements for operation on its network.
For small tests, that difference may not matter. For enterprise rollouts, multi-site deployments, or customer projects where approval delays can affect schedules, it can shape the gateway decision from the start.
Meet The Verizon-Certified WisGate Edge Lite 2 RAK7268CV2-V Variant
RAK7268CV2-V indoor gateway for LoRaWAN with Verizon certification for US LTE enterprise deployments
The WisGate Edge Lite 2 RAK7268CV2-V is the Verizon-certified variant of the WisGate Edge Lite 2 product line. It is built for US deployments where LoRaWAN coverage, LTE backhaul, and carrier approval need to work together before rollout.
WisGate Edge Lite 2 Verizon keeps the core WisGate Edge Lite 2 feature set while adding the certification path needed for Verizon-network deployments.
WisGate Edge Lite 2 Verizon is especially relevant when the project needs:
  • Indoor 8-channel LoRaWAN coverage
  • LTE Cat 4 backhaul
  • Verizon certification for US deployments
  • External LTE antenna support
  • PoE and 9-36V DC input
  • WisGateOS 2 and WisDM cloud management
  • Zero Touch Provisioning
  • Secure MQTT over TLS and LoRa® frame buffering
  • Compatibility with major LoRaWAN network servers
What’s New Compared with RAK7268V2 and RAK7268CV2?
The main difference is the deployment requirement each variant is built for. RAK7268V2 is for indoor sites that already have Ethernet or WiFi. RAK7268CV2 adds LTE Cat 4 for cellular backhaul. RAK7268CV2-V adds Verizon certification for US deployments where carrier approval is required or preferred.
Version
Connectivity
Best For
RAK7268V2
Ethernet and WiFi
Indoor deployments where wired or WiFi internet is already available
RAK7268CV2
Ethernet, WiFi, and LTE Cat 4
Sites that need LTE backhaul, cellular redundancy, or flexible installation where wired internet may not be available
RAK7268CV2 with external LTE antenna
Ethernet, WiFi, and LTE Cat 4 with external LTE antenna
Weak-signal areas, remote rooms, industrial indoor spaces, and deployments that need stronger LTE reception
RAK7268CV2-V
Ethernet, WiFi, and LTE Cat 4 with Verizon certification
US deployments where Verizon certification is required or preferred
WisGate Edge Lite 2 Verizon does not create a separate gateway category. It adds a Verizon-certified option to the WisGate Edge Lite 2 lineup, with external LTE antenna support and 9–36V DC input for deployments that need stronger cellular reception, wider power flexibility, and carrier-approved hardware.
How Our Verizon-Certified Gateway for LoRaWAN Reduces Procurement and IT Approval Friction
For enterprise IoT, deployment delays often happen before the gateway is installed.
A facility team may know where sensors are needed. A system integrator may already have the network design. An IT team may know which LoRaWAN network server or cloud platform will be used. But the project can still pause if the gateway cannot pass device approval, procurement review, or carrier requirements.
WisGate Edge Lite 2 helps reduce that friction by giving teams a Verizon-certified indoor gateway option for US deployments.
Team
What RAK7268CV2-V Provides
How It Reduces Friction
Procurement
A Verizon-certified indoor gateway with a defined product variant
Gives buyers carrier-approved hardware to evaluate and specify
IT
Secure MQTT/TLS, WisDM remote management, and standard LoRaWAN deployment support
Helps the gateway fit security reviews and existing management workflows
System Integrators
A repeatable WisGate Edge Lite 2 variant for Verizon-network projects
Makes it easier to standardize gateway selection across customer deployments
For organizations already using Verizon enterprise connectivity, this helps align gateway deployment for LoRaWAN with existing carrier requirements instead of treating approval as a separate obstacle.
RAK7268CV2-V gateway approval flow showing LoRaWAN sensors, Verizon LTE, IT review, and cloud connectivity
Deployment Benefits: External LTE Antenna, ZTP, WisDM, Secure MQTT/TLS, and Frame Buffering
Verizon certification helps with approval, but RAK7268CV2-V also needs to work well in real indoor IoT environments. These features support reliable LTE backhaul, easier rollout, remote management, and secure LoRaWAN data handling.
External LTE Antenna Support
Indoor LTE performance depends on gateway placement, wall materials, cabinet location, and signal quality. RAK7268CV2-V supports two external LTE antennas to help improve reception in weak-signal indoor areas, equipment rooms, and industrial spaces.
PoE and 9–36V DC Input
RAK7268CV2-V supports PoE and 9–36V DC input, giving teams more flexibility when powering the gateway through Ethernet infrastructure or available facility power.
ZTP helps reduce manual setup by allowing the gateway to arrive pre-configured for the intended deployment. This is useful for repeatable or multi-site rollouts. Instead of configuring every gateway individually on site, teams can prepare a consistent configuration before units are deployed.
WisDM Cloud Management
WisDM lets teams monitor, configure, and update gateways remotely. This helps reduce unnecessary site visits and supports easier management across multiple deployed gateways.
Secure MQTT/TLS and Network Server Flexibility
RAK7268CV2-V supports secure MQTT/TLS and common LoRaWAN network server options, including ChirpStack, The Things Stack, AWS IoT Core for LoRaWAN, Actility, and Loriot.
LoRa Frame Buffering
Buffered packets are forwarded automatically once connectivity is restored. This supports more reliable monitoring for smart buildings, equipment rooms, and remote indoor sites.
Which Version Should You Choose?
Choose the WisGate Edge Lite 2 variant based on the deployment environment, backhaul requirement, and approval requirement.
Also, see how we compare the RAK7268CV2-V with other indoor gateways.
Choose this version
When to choose it
RAK7268V2
Choose this if the site already has reliable Ethernet or WiFi and LTE is not needed.
RAK7268CV2
Choose this if the deployment needs LTE Cat 4 backhaul, cellular redundancy, or flexibility where wired internet may not be available.
Choose this if the site needs stronger LTE reception in weak-signal indoor areas, remote rooms, cabinets, or industrial indoor spaces.
RAK7268CV2-V
Choose this if the deployment is in the US and Verizon certification is required or preferred for carrier approval, IT review, or procurement requirements.
For teams that are not sure how to choose the right gateway, the deployment checklist should start with four questions:
1. Will the gateway use Ethernet, WiFi, or LTE?
2. Is the site using Verizon LTE in the US?
3. Does procurement or IT require carrier-certified hardware?
4. Does the installation need external LTE antenna support or wider DC input?
If the answer includes Verizon LTE and certification requirements, RAK7268CV2-V is the best fit.
Frequently Asked Questions: Verizon, Other Carriers, Power Input, Indoor/Outdoor Use, and Pricing
Is RAK7268CV2-V a completely new gateway?
No. RAK7268CV2-V is not a separate gateway family. It is the Verizon-certified variant of WisGate Edge Lite 2 Verizon, designed for US deployments where carrier approval is required or preferred.
What is the difference between RAK7268V2, RAK7268CV2, and RAK7268CV2-V?
RAK7268V2 is the non-LTE version for Ethernet and WiFi deployments. RAK7268CV2 adds LTE Cat 4 connectivity for cellular backhaul. RAK7268CV2-V is the Verizon-certified version for US deployments where Verizon certification is required or preferred.
Does RAK7268CV2-V only work on Verizon?
Verizon certification does not prevent the gateway from operating on other compatible LTE networks. Compatibility with another carrier depends on that carrier's supported LTE bands, SIM policies, and certification requirements.
Why choose the Verizon-certified version if the standard CV2 already has LTE?
Choose RAK7268CV2-V when certification matters for the deployment. A standard LTE gateway may be technically suitable, but enterprise buyers may still need formal carrier approval before procurement, IT, or deployment teams can move forward.
Does WisGate Edge Lite 2 Verizon support PoE?
Yes. WisGate Edge Lite 2 Verizon includes PoE, which is useful when Ethernet and power can be delivered through the same network path.
What power input does RAK7268CV2-V support?
The WisGate Edge Lite 2 Verizon lineup supports PoE and DC power input options. For RAK7268CV2-V, the available DC input range is 9–36V.
Is WisGate Edge Lite 2 Verizon for indoor or outdoor use?
WisGate Edge Lite 2 Verizon is an indoor gateway. For outdoor or rugged deployments that need IP67 protection, the product content points to rugged RAK gateway options such as WisGate Soho Pro.
What network servers are supported?
WisGate Edge Lite 2 Verizon supports multiple network server and protocol options, including the built-in LoRa Network Server, UDP Packet Forwarder, Basics Station, MQTT Bridge, secure MQTT with TLS encryption, ChirpStack, The Things Stack / The Things Network, AWS IoT Core for LoRaWAN, Actility, and Loriot.
Want specs, pricing, and ordering options for the WisGate Edge Lite 2 Verizon?
Shop the RAK7268CV2-V
Need compliance details?
View certification documentation
