RAKwireless Bulletin: Off-Grid Power, Meshtastic Nodes & LoRaWAN® Field Deployments
Welcome to the latest RAKwireless Bulletin.
The past month brought dedicated off-grid power infrastructure, out-of-the-box Meshtastic hardware, modular gateway fleet automation, and extensive field deployments spanning agriculture, smart buildings, and industrial telemetry across Europe, Africa, and Australia.
Discover our new hardware and real-world deployments. We also highlight our teams’ presence across major industry events across Europe.
TL;DR
- Announced new products: Battery Prime, WisMesh Pod, and WisNode Tag tracker.
- Published a video series with walkthroughs addressing key operational scenarios using WisDM Metrics.
- Highlights real-world deployments featuring multi-sensor smart buildings, electric fence protection, UK industrial air filtration monitoring, and gateway-mesh water metering.
- RAKwireless formalized an operational architecture partnership with LORIOT.
- Wrapped up successful keynotes and technical sessions in Amsterdam, Valencia, London, Prague, Barcelona, and Munich.
New Hardware & Power Infrastructure
Battery Prime Brings Reliable Off-Grid Power for Gateway Deployments
Power reliability remains the greatest operational challenge for outdoor and remote infrastructure on LoRaWAN®. The new Battery Prime delivers a compact and cost-effective off-grid power source for industrial deployments: environmental monitoring, agriculture, and remote infrastructure.
We showcased its key features at a live monitoring dashboard demo in the electronicaFair 2026.
WisMesh Pod Provides Plug-and-Play Meshtastic Communications
For off-grid teams, emergency volunteers, and outdoor explorers, deploying mesh communications should not require soldering irons or command-line flashing tools. The WisMesh Pod delivers a complete, factory-assembled Meshtastic node out of the box.
It pairs directly with the Meshtastic companion app over Bluetooth to enable instant text messaging and location sharing anywhere cellular networks fail.
WisNode Tag, The New Ultra-Slim Asset Tracker for LoRaWAN
Asset tracking demands form factors that fit unobtrusively onto pallets, equipment, and personal badges. The WisNode Tag combines a slim profile with wide-area LoRaWAN reach, integrated GNSS, and a 3-axis motion accelerometer.
Built to integrate natively with the TrackIt™ mobile tracking suite, it reports real-time positions, movement alerts, and SOS events through public networks or private WisGate Edge gateways.
Video Walkthroughs & Technical Best Practices
WisDM Metrics Video Series
A functioning gateway doesn't always guarantee reliable sensor delivery. Over the past month, we published five video walkthroughs addressing key operational scenarios using WisDM Metrics:
- Build a Custom Dashboard: Create tailored, no-code dashboard widgets to monitor critical gateway counts by site and firmware version.
- Reachable Status Isn't Enough: Learn how to check gateway health.
- Catch Backhaul Changes Early: Configure alerts to catch silent shifts before receiving unexpected carrier invoices.
- Isolate High-CPU Gateways: Use fleet Table View filters to identify high-CPU gateways.
- Signals in Missing Sensor Data: Analyze and identify local RF interference or channel saturation on sensors.
RF Architecture Essentials: Understanding Antenna Gain
In the latest issue of Beyond Connectivity, our engineering deep dive explains the vertical beamwidth compression inherent to high-gain omnidirectional antennas, demonstrating why a balanced 2–3 dBi antenna frequently outperforms 8 dBi antennas in hilly topography and multi-story indoor installations.
Engineering Guide: Battery-Powered vs. External 5V Powered Nodes
Deciding between battery power and external 5V supply affects everything from casing dimensions to long-term site visit budgets. Our hardware engineering team published a practical selection breakdown comparing battery-backed nodes against external 5V power designs.
LoRaWAN & Meshtastic Deployment Use Cases
Envionix Modernizes Commercial Facades & Building Health
Smart building specialist Envionix deployed RAK Sensor Hubs alongside WisGate Edge gateways to capture indoor climate, acoustic dynamics, and facade structural telemetry. By eliminating conventional conduit wiring, the project cut commercial retrofit deployment schedules significantly.
LumiCore Migrates to Wireless LoRaWAN-based Monitoring System
LumiCore Systems replaced aging manual loggers across clinical cold rooms, blood banks, and food processing plants with calibrated LoRaWAN temperature/humidity sensors and WisDM-managed gateways, establishing automated, audit-ready compliance reporting with zero operational disruption.
EcoWild Net Establishes Solar Electric Fence Monitoring in Namibia
In remote Namibian wildlife reserves, fence perimeter breaches lead to human-wildlife conflict and livestock losses. EcoWild Net deployed custom solar-powered LoRaWAN monitors engineered around RAK WisBlock modules to track fence pulse integrity and transmit instant breach coordinates across cellular-dark terrain.
Predictive Air Filtration Maintenance Across 30+ UK Industrial Plants
A leading UK environmental air filtration provider deployed over 400 custom sensor nodes based on the RAK3172 paired with RAK7268V2 gateways. By monitoring differential pressure across filter banks in real time, maintenance teams transitioned from rigid calendar rounds to condition-based filter servicing.
Koelus Solves Cable Trenching with Gateway Mesh in Madrid
Trenching data cables across an active industrial site in Madrid was cost-prohibitive. System integrator Koelus solved the problem by deploying three WisGate Edge Lite 2 (RAK7268) gateways configured in a wireless gateway mesh, aggregating utility water meters and relaying data through a single central WisGate Connect master gateway.
WisGateOS 2’s Automated Network Rollback Saved the Day
System integrator Marc van Bracht shared a real-world field experience where a remote gateway was saved by WisGateOS 2's automated network rollback. After an APN typo was applied to an LTE gateway on a distant mast, the system automatically reverted to the previous known-good profile and restored connectivity thereby preventing a costly on-site service call.
Community Showcases & Field Innovations
High-Altitude Atmospheric Balloon Platform Built on RAK3172
Community maker Teddy Warner revealed an open-source high-altitude balloon tracking payload powered by the RAK3172. Relaying atmospheric pressure, ambient temperature, light levels, and motion vectors over The Things Network, the balloon payload double-functions as a high-altitude line-of-sight repeater for long-range environmental tags.
Custom DIN-Rail Industrial PLC Powered by RAK3172
Developer Jose Meneses, supported by Carl Erick Rowan from the RAK team, created a compact, open industrial controller around the RAK3172. Housed in a custom 3D-printed enclosure, the board bridges legacy machinery into LoRaWAN SCADA systems.
RAKwireless at Events
RAKwireless at IoT Sparks 2026: Xose Pérez and Gavin Brown connect with attendees and IoT innovators in Valencia, Spain.
IoT Sparks 2026 | Valencia | October 6-7
RAKwireless and LORIOT showcased an architectural partnership: the LORIOT Edge Agent (LEA) directly handles LoRaWAN routing and packet forwarding, while RAK WisGateOS 2 and WisDM handle base OS telemetry, remote container updates, and hardware monitoring. At the event, Xose Pérez also addressed European enterprise attendees on applying AI heuristics to fleet operations.
Zephyr Development Summit | Prague | October 7-9
Embedded Software Developer Sercan Erat was at the event to exchange ideas, learn from other developers, and talk about RAKwireless hardware, LoRaWAN, and Zephyr development.
Smart Buildings Show 2026 | London | October 14-15
VP Strategic Growth & Design Partner Gavin Brown was at the event where he talked about how smart-building deployments are scaling with LoRaWAN.
Smart City Expo World Congress 2026 | Barcelona | November 3-5
Gavin Brown headlines the panel discussion at the LoRa Alliance Pavilion in the Smart City Expo World Congress where they talked about the use case of smart metering as an ROI and infrastructure foundation in wider city digitalization initiatives.
electronicaFair 2026 | Munich | November 10-13
RAKwireless co-exhibited with Edge Computing Workbench's edge lab LIVE at electronicaFair 2026, where we talked about IoT edge technologies and their practical applications in industrial IoT. We also showcased the Battery Prime, alongside a live demonstration of edge computing gateway appliances.
This Month in One View
A complete IoT architecture requires every layer to pull its weight from energy capture and RF hardware to edge operating systems and fleet orchestration.
Over the past month, we advanced each stage of that stack: introducing our latest hardware launch, new firmware releases, and deepening our industry partnerships.
Whether your infrastructure is deployed across rooftop solar nodes, complex industrial plants, or off-grid wildlife reserves, RAKwireless continues to deliver the connected building blocks that make production deployments dependable at every tier.
Explore LoRaWAN IoT solutions, Meshtastic hardware, and off-grid power options for your next deployment.
IoT Made Easy,
The RAKwireless Team
