Monthly Digest: NEW Products, Milestones, and Updates to End the Year Strong
As we close out 2024, we’re proud to share the highlights of a remarkable year. From launching cutting-edge products like the Signal Meter RAK10706 to achieving ISO certifications for our Shenzhen factory, we’ve set new benchmarks in IoT innovation.
Bridge IO Solutions
RAKwireless Bridge IO solutions simplify IoT retrofits in industrial and building automation. They connect legacy systems using standard protocols to modern networks over LoRaWAN®, enabling cost-effective and scalable deployments.
The Solutions:
RAK2470
An outdoor RS485 Modbus to LoRaWAN converter, designed for demanding industrial environments like solar farms and remote asset monitoring.
View Product
RAK2461
An indoor IO module with versatile input/output options, ideal for HVAC systems, lighting control, and energy management in smart buildings.
View Product
RAK2462 (Coming Soon)
A new indoor model with advanced features, including analog outputs for precision control and thermal monitoring capabilities, supporting complex systems like refrigeration and climate control.
What is IO.Box?
IO.Box is a cross-platform configuration tool designed to streamline the setup of RAKwireless Bridge IO devices. It simplifies device configuration, reduces deployment time, and minimizes errors through features such as:
- Automated LoRaWAN Channel Configuration
- Seamless LoRa Network Server Integration
- Bulk Import/Export of Device Settings
With real-time testing and monitoring tools, IO.Box ensures precise configurations, making large-scale IoT deployments faster and more efficient.
Product Updates
The latest updates to our software tools bring enhanced functionality and ease of use for managing LoRaWAN networks.
WisGateOS 2 v2.2.10
- Pre-configuration restoration for Basics Station after factory reset.
- Cat-1 LTE support for RAK7267 SOHO Pro.
- GPS data export to the local host.
- Updated forwarder URL to TTN default.
- Fixes include improved UI graphs and resolution of WisDM-related agent issues.
WisDM v1.8.1
- Flexible payment options for customized plans.
- Improved gateway search by name, SN, or EUI across the platform.
- Renamed Beta Subscription to On-Demand Subscription for clarity.
- Updated tiered pricing for better value on Enterprise plans.
Discover NEW RAK Products
Open Source Low-Cost LoRa®/LoRaWAN Signal Meter RAK10706
Introducing our new Signal Meter RAK10706—a compact, cost-effective tool designed for testing LoRa/LoRaWAN coverage with precision and ease.
Key Features:- LoRaWAN Coverage Testing: Instantly measure gateway range, RSSI, SNR, and link margin without needing a cloud backend.
- LoRa P2P Testing: Send and receive custom payloads for flexible peer-to-peer coverage analysis.
- On-the-Go Adjustments: Modify settings directly on the device—no computer required.
- Long-Lasting Performance: A 3200mAh battery and low-power OLED display ensure extended usage.
- Optional Data Logging: Save test results on an SD card for easy post-analysis.
- Open-source firmware for customization and community collaboration.
- Compact and portable design with a user-friendly single-button interface.
- Durable enclosure with an RP-SMA antenna connector and GNSS location module onboard.
RAK3172-T with ±0.5ppm TCXO
The new RAK3172-T is designed for timing-sensitive RF applications, ensuring high precision even under extreme temperatures. Equipped with an enhanced ±0.5ppm TCXO, this module goes beyond LoRa® capabilities. The STM32WL inside RAK3172-T now supports additional RF modulations, including narrowband FSK, Sigfox, and custom RF applications, offering greater flexibility for your projects.
WisMesh Pocket Mini
The WisMesh Pocket Mini is a lightweight, pocket-sized device for the Meshtastic LoRa Mesh Network. Pre-flashed with Meshtastic firmware, it’s ready to use with minimal setup. Smaller and simpler than the WisMesh Pocket, it features a 1000mAh battery with an on/off button, easy USB access, and visible status LEDs. Perfect for those who need portability and core functionality
Explore Our Blog: Stories Behind RAKwireless Innovations
How Our Modular Vision for IoT Began
RAKwireless began with a goal: simplify IoT for developers. Hardware complexity often slows innovation, so we created WisBlock—a modular system combining sensors, computing, and connectivity to streamline IoT solutions.
Real IoT in a Box: IoT Made Simple
With the Real IoT Solutions Marketplace (RISM), deploying IoT is effortless. Our all-in-one kits include sensors, connectivity, and dashboards, ready to tackle real-world challenges like monitoring condensation, CO₂ levels, and air quality. Setup is as easy as scanning a QR code, helping industries from logistics to smart buildings achieve quick, impactful results.
RAKwireless Achieves ISO9001 and ISO27001 Certifications
Our Shenzhen factory has officially earned ISO9001 (Quality Management) and ISO27001 (Information Security) certifications through a rigorous audit by LRQA, a globally respected authority.
This milestone reflects our commitment to real, embedded quality and security standards—not shortcuts. Since early 2024, our team has integrated ISO principles into our operations, including ERP and MES systems, ensuring traceability and consistent quality control.
Upcoming Events
Stay tuned for announcements on upcoming events like CES, the global stage for innovation, where you can connect with us and explore the latest IoT advancements. Join us to experience groundbreaking technology shaping the future of connectivity.
As always, we are excited to share these updates.
Your continuous support and feedback drive our innovation.
Thank you for being part of our journey. Here’s to a successful 2025!
