GPS Location Trackers: Why to Choose TrackIt Over Others In The Market
GPS trackers have become an essential tool for many businesses and individuals looking to keep track of their assets, vehicles, and even loved ones. With so many options available in the market, it can be challenging to choose the right fit for your needs. In this article, we’re comparing the RAKwireless WisNode TrackIt to other popular GPS trackers in the market and highlighting its unique features.
The RAKwireless WisNode TrackIt is a LoRaWAN® GPS tracker designed for asset tracking. It uses the LoRaWAN network to communicate with a gateway, while the GPS module provides location information. One unique feature of the WisNode TrackIt is its Helium-readiness, which allows it to communicate with the decentralized Helium network for increased coverage. This feature is particularly useful for businesses that require extensive coverage for their assets, which the Helium network provides in many cities globally.
In comparison to Bluetooth-enabled trackers like Apple AirTags, the WisNode TrackIt has a longer range and can provide real-time location information, even when out of range of your home gateway. Additionally, the WisNode TrackIt's LoRaWAN connectivity provides long-range communication, allowing the device to communicate with the gateway from several kilometers away.
In comparison, the Tile Mate is a popular Bluetooth-enabled tracker that uses Bluetooth technology to communicate with the Tile app on your phone. However, the range of the Tile Mate is limited to about 200 feet, which means that you may not be able to track your assets if they are too far away. In contrast, the WisNode TrackIt's LoRaWAN connectivity provides long-range and low-power connectivity, allowing it to communicate with the gateway from several kilometers away.
Another popular choice is SPOT Trace, a satellite-based tracker designed for asset tracking in remote areas. It uses satellite communication to provide location information, making it an ideal choice for businesses that need to track their assets in areas with no cellular or network coverage. However, the SPOT Trace is significantly more expensive than the WisNode TrackIt, both in terms of device cost and subscription fees.
Another advantage of using a LoRaWAN GPS tracker like the WisNode TrackIt are its security features. The device uses encryption to secure communication between the device and the gateway, ensuring that the location information of your assets remains private and cannot be intercepted by unauthorized parties. The WisNode TrackIt also has an anti-tamper feature that sends an alert to the server if someone tries to remove the device.
In conclusion, the RAKwireless WisNode TrackIt has several advantages over other popular GPS trackers in the market. Its long-range and low-power connectivity, Helium-readiness, real-time location tracking capabilities, and security features make it an ideal choice for asset tracking applications. Whether you’re looking to track your assets for personal or business use, the WisNode TrackIt can provide extensive coverage and real-time location tracking capabilities. With a LoRaWAN GPS tracker like the WisNode TrackIt, you can be confident that your assets are secure and accounted for at all times.
